It is currently Tue Jul 22, 2025 11:38 pm
PostPosted: Sun Mar 04, 2007 5:45 am
...on an additional note, I was planning on mounting my 690 upside-down, in a home-made table setup, and I ran into a little problem: how to mount the darn thing. I was thinking of 'simply' mounting it using the three tapped holes in the base, but then realized I can't actually go down to the local shop and get any US-standard bolts.
So, could any of you guys with 690's tell me what thread/size screws I need to order (wanted to get some stuff from McFeely's anyway) to fit the 690's thread?
Thanks in advance.
PostPosted: Sun Mar 04, 2007 6:39 am
Mattia...why can't you just remove the screws from the router plate and use the same ones to mount the router to your table plate?
Anyway...they're 24TPI and 3/16". You may need a few different lengths. I'd suggest 1/2" and 3/4" for starters.
PostPosted: Sun Mar 04, 2007 8:23 am
Thanks for the info,.
It's the length issue; I haven't settled on the material for the table plate yet, but I'd like to go a little thicker than the router's own baseplate.
PostPosted: Sun Mar 04, 2007 10:18 am
mattia, pm me with your address if you need some sent over...
PostPosted: Sun Mar 04, 2007 10:51 am
Mattia, The ones I used in mine are the same as JJ's but 1" long.
PostPosted: Sun Mar 04, 2007 12:56 pm
First name: Jim
Last Name: Kirby
[QUOTE=JJ Donohue] Mattia...why can't you just remove the screws from the router plate and use the same ones to mount the router to your table plate?
That's what I did. Got a Rousseau plate and built a table top for it, and just reused the original screws.
Jim
Jim Kirby
kirby@udel.edu
PostPosted: Mon Mar 05, 2007 2:46 am
[QUOTE=JJ Donohue] ...they're 24TPI and 3/16"......[/QUOTE] JJ,
Could it be a #10-24?
3/16" = .1875"
#10-24 is .190".
